jdcellarmod
Mar 19, 2014Explorer
Hi Mike,
I have a 2014 855S. I opened the bottom of my camper because I want to change the water level sensors for all of my tanks. On the bottom, take out the screws up front and about 1/2 to 2/3 back on each side. Be careful as the bottom is just thin plywood. I plan on replacing the plywood with something non wood. I found the front support bracket that holds up the fresh water tank connected on only one side. Took care of that. Up front on the tank are the connections for the drain and the pump connection. Good luck. PM me if I can help further.
Jeff D.
Jeff D.
