fallsrider
Nov 13, 2015Explorer
Gene&Ginny wrote:Thanks. I will dig into it some more hopefully this weekend.
Glad to hear you made progress.fallsrider wrote:There is one screw near the base of the ignitor that will let you remove the plate that holds the burner tube and the ignitor. You have to wiggle it a bit to get the end of the burner tube out of the slot at the end of the burner tube.
.... I could not figure out how to get the burner out. ....
Yesterday, with a high of around 75*, with it 70* inside the trailer, and with the sun shining on the fridge side (street side) of the trailer, the fridge creeped up to 44* set on high. That's not near as good as electric, but it is better than its performance this past weekend when it was a little cooler and it would only maintain 50* or so.
I want to try to improve its performance some more. We'll see if I can. I'm one of those people that wants every option to work as best it can. Even if I don't use it much.
44,068 PostsLatest Activity: Apr 17, 2021
