enblethen
Nov 13, 2015Nomad
You may want to check the venting for better performance.
Check the distance from the coils to the outer wall. This should be only about an inch maximum. I closed up the bottom, just above the access door with some foam board attached with Liquid Nails.
Look in from the top. See if the top of the refer has a piece of sheet metal to divert the air flow away from the void on top of refer. When I had my refer out, I got a piece of 6 or 8 inch furnace duct. Left it apart,, not full circle, and attached it to the structural material to form an arc.
Of course it only pertains to a refer not in a slide!
This really helped air movement and cooling!
44,068 PostsLatest Activity: Apr 17, 2021
