TheBeans's avatar
TheBeans
Fridge beeping
We're getting our new rig ready for it's shake-down trip and we turned the fridge on to pre-chill and it started to beep and a light flashed. This is a 2-wway Dometic of some sort (don't have the manual in front of me). We're trying to run the fridge with electricity (gas is off) and the check light goes on and beeping after about 30 seconds. The check light from what we understand is to alert for no gas. Why would the check light go off with electricity only?
So, we've done all the usual stuff to remedy this situation and nothing is working. Anyone have any suggestions that might help? We'll be calling the dealer on Monday morning if we can't get this figured out but I thought I'd tap the knowledge here too.
  • Are you plugged into shore power electric? Do your outlets work?
    You say "gas is off" meaning shut off at propane tanks, or fridge is not set to gas?
    If shore power electric is not being supplied, fridge will default to gas. Are you sure your fridge is plugged into its proper outlet? Did you test fridge outlet to confirm power?
    Jerry
