StirCrazy wrote:
Ok, just wanted to see if anyone with older non DSI fridges have an issue with it blowing out on the highway and what you did to fix it. I have a Dometic RM2510 that actualy works good and for the most part stays lit. if it is a gusty day at highway speeds it will blow out the pilot on a big wind gust. also it is more prevailant in the cooler wether when the pilot is at low flame.
what I am wondering is if there is a way to put some sort of windscreen/baffel etc. with out aftecting natural airflow.
thanks
Steve
Mine had the same problem. I taped off the lower louvers in the outside vent and that pretty much took care of the problem.
