Old-Biscuit
Jul 30, 2018Explorer III
AlmostAnOldGuy wrote:
DW moved clip slightly up. Now cooling. That is twice now we have observed fridge warming up and slight move makes big difference. I have trouble explaining why slight move makes such a difference nor do I see why after a couple days it warms up again.
Perhaps wire loose on clip or connection?
Clip is just a holder for the thermistor
Thermistor measures fin temp and thermostat uses that to control heating cycles
Did you get any 'fault codes'......LED display lights flashing etc?
Lamp/thermistor connector dirty/loose?
(moving clip doesn't really help on a fridge that has adjustable temp settings.....more for those models with 'AUTO Temp Control')
Messing with thermistor means wiring issue or thermistor failing
Unplug thermistor go to max cooling temps setting (5) and let fridge run overnight..then measure temps
44,068 PostsLatest Activity: Jun 14, 2026
