CavemanCharlie
Aug 02, 2018Explorer III
SidecarFlip wrote:
Simple and less expensive answer to an absorbtion fridge that don't work well.. A Danfoss Secop compressor fridge. Very efficient (residential units aren't they are power hogs). A Sanfoss Secop fridge is a duty cycle fridge. That is, the compressor (which is brushless and very efficient) runs only enough to hold a set temp and it automatically reduces power use by itself.
In cool down from ambient mode a Danfoss/Secop might pull 5 amps, but once it reaches set temp, it reduces it's power drain to less than 2 amps. About what an amonia fridge pulls with auxiliary fans installed.
Plus, no special venting and they are not affected by high ambient temps. Finally both Dometic and Norcold make drop in replacement units. Basically plug and play for about 800 bucks.
Your really sold on these things. And, they may indeed be great for a lot of people. I am still not sure they would work for me though. They do draw some currant. Not a lot but, some. I go camping for 2-4 days with 2 batteries and I don't know if it would be enough to keep this type of fridge going. Sure, I could then put on solar panels. But, I would have to add that to the cost of the fridge. And, I always try to camp in the shade. Solar doesn't work then.
I think I'll stick to my absorption fridge for now. But, I have a older good one. Some of the new ones don't work very well. i can tell by looking which ones to avoid.
44,068 PostsLatest Activity: Jun 14, 2026
