enblethen
Nov 13, 2015Nomad
Don't condemn the element, yet!
What happens when you switch to 120 volts AC on control panel?
If it refuses to go, the receptacle could be dead, check it for power.
Next check the control board fuse.
Next check the output on the control board for 120 volts going to the element.
No out put could indicate the 120 volt relay has gone bad. replace board with Dinosaur Electronics one.
Check the element for continuity. Open would indicate element is bad. Fairly easy to replace. element should be around $75.
44,056 PostsLatest Activity: May 04, 2014
