CavemanCharlie
Nov 14, 2015Explorer III
Johno02 wrote:
There should be a 120v outlet with the fridge plugged into it. Check voltage at plug, then make sure plug in inserted OK
Yes start here. If you can access the receptacle where your fridge is plugged into.
I once had a problem where the fridge quit and the receptacle in the bathroom was one of those GFCI types and the fridge was wired in on the same circuit. So when the bathroom outlet clicked out the fridge quit too.
44,056 PostsLatest Activity: May 04, 2014
