leatherhead612's avatar
Nov 04, 2017
Fridge operation when not level
We are nose high on our site. Set up in the dark on a downhill site. Does the fridge have problems cooling only on lp if the site is not level, or if hooked up to shore power as well?
Will try to get more level in the am. Thanks in advance
  • Lynnmor wrote:
    It is not about operating so much, it is about destroying the cooling system. It must be within 3 degrees side to side and 6 degrees front to back.
    X2. If it's having a hard time cooling while out of level, your likely doing permanent damage.
    It does not matter what energy source it's using to operate.
  • It is not about operating so much, it is about destroying the cooling system. It must be within 3 degrees side to side and 6 degrees front to back.
