sign_man's avatar
sign_man
fridge pilot light
the pilot light on my new 2015 puma fridge keeps going out after an hour or so. and the check light does not come on. when i turn it off & on it lights right up. but then a little later its out again. my question then is: Does the pilot light go out when the refrig gets cold enough?
  • Also with a new install you can have air in the system and that will interfere with operation until it is cleared out. I've run the stove for 5 mins to help minimize the issue.
  • There is no pilot flame---that IS the main flame
    Fridge thermostat controls heat source (electric and propane) based on temp setting
    Fridge warms up....t-stat starts cooling cycle (opens gas valve/ignites main flame) Then when cooled back down......closes gas valve/main flame goes out.
    NEW 2015 RV........then you should have a owners manual for fridge (water heater, A/C Unit, furnace, converter etc).
    Makes for good night time reading.
