Flatfive wrote:
Okay. It's working now. I went out and turned the fridge on "gas" then I walked around the back and I could hear the sparking of the igniter. Click, click, click. Every second a strong click. Okay I've got gas, got spark. What's the problem? I took the cover off to see the back of the fridge. I could see that a spark was jumping from the white wire to a pipe, right through the insulation. The wire was touching the pipe. So I just moved the wire away from the pipe and the fridge started working! I will put some more insulation on that white wire.
Thank you for letting us know you found the solution. It might help someone else out someday that has the same problem too.
