The electric part of our Dometic frig has quit working. It cools fine on propane. But will not switch over to electricity when plugged in. What should I check first? Thanks in advance!
Swapping to LP (not staying on AC when in AUTO ) means fridge does NOT see any 120V AC power Outlet or fuse.
Check the 120V AC outlet that fridge plugs into......got 120V AC power??
If YES.... Then remove the control module cover (have to unplug 120V AC cord and DC leads) Then check if the 5A glass fuse has blown. If blown...new fuse and a new electric element
