schlep1967
Apr 08, 2021Nomad
ticki2 wrote:
If you are in the middle of nowhere you should be able to find a small fallen tree , maybe 6” diameter . Take the weight of the camper off the bed with the jacks . Measure the height and cut a section of log and jam it in between the frame and bed . Lower the camper and between the weight and the tie downs it should stay there if you take it easy .
This. Any solid object the right size would work. A piece of fire wood split to the correct size etc.
