Passin_Thru
Aug 29, 2016Explorer
If you have a big enough shop. Pull off the skin and replace it. Make sure it's dry underneath. It's not impossible and you can buy sheets of fiberglass at a lot of places. You may have to use a router to clean up the glued down areas. Wear light rain gear, tape the arms and legs shut and a complete face cover with a breather. I rebuilt Radomes on P3s and its a job. Make sure shop is warm, Eposxy needs to be around 100 degrees before application, sanding is, well, grueling. Start with 80 grit and work down to 200. Study up on boat repairs.
