AmericalVette
Aug 29, 2016Explorer
imq707s wrote:Passin Thru wrote:
If you have a big enough shop. Pull off the skin and replace it. Make sure it's dry underneath. It's not impossible and you can buy sheets of fiberglass at a lot of places. You may have to use a router to clean up the glued down areas. Wear light rain gear, tape the arms and legs shut and a complete face cover with a breather. I rebuilt Radomes on P3s and its a job. Make sure shop is warm, Eposxy needs to be around 100 degrees before application, sanding is, well, grueling. Start with 80 grit and work down to 200. Study up on boat repairs.
Not sure I want to mess with fiberglassing it....done fiberglass work before, and its a mess. I think the powder coated aluminum sheets are the best option. Easy to install, looks great, and you never have to worry about it delaminating again.
Good luck with the project. I hope you have a chance to post some photos during the process. Best wishes!
