BradW wrote:
I could really tell the front end had a significant effect on the side to side rocking when I had Rancho 9000 adjustable shocks on all four corners of our srw trucks. I experimented quite a bit with different setting and I found that without the camper I needed run the front socks on nearly the softest setting and with the camper I needed run the front shocks on nearly the stiffest setting. The front shocks had almost as much (maybe 70% - 80%) effect as the rear shocks on reducing side to side rocking.
bradw
Thank you for the additional information, I may play with my front pressure.
