Urriellu wrote:
Hello, I have a Ford Ranger 2019 that does 18-21mpg on the highway at around 65mph. I have just purchased a GD 17MKE which is a 21', 6400 GVWR, travel trailer.
I expected to go from 18-21mpg not towing down to maybe 11-13mpg while towing.
Unfortunately I'm doing 8.5mpg at 65mph or 7.4mpg at 75mph.
My brake controller seems to work. RV tires are at 60psi, truck tires at 40psi.
Does this seem reasonable?
Thank you!
Sounds about right. However you are more than likely out running your tires. There are only about 3 ST tires that are rated for more than 65MPH. And the manufacturer probably didn't spring for the extra money. Plus 75 is awful fast to be towing 6000lb with a small truck
