4x4van wrote:
Gdetrailer wrote:
4x4van wrote:
I have to laugh at the tow capacity wars that the manufacturers are currently waging with small/midsize trucks.  Towing a 6400lb trailer with a small 4000lb truck at 75mph?  While it may be able to TOW it, and it may be able to STOP it (with trailer brakes), in an emergency maneuver, the trailer will drive the truck.    Hope I'm nowhere near the OP when that happens.
Trailer brakes generally are required items once you go above 2,001 lbs in some states and 3,001 lbs in most all other States. So in reality, yes, a "4,000 lb" truck CAN safely not only tow but STOP.
The trucks brakes handles the weight on the truck up to the rated GVWR and the trailers brakes handles the trailers weight up to the rated GVWR.
So in reality, it CAN be safely done, might not be pretty or fun but still very possible to safely stop during emergency maneuvers.
A lot of folks out there towing even greater of a mismatch, while that doesn't make me feel safe it is the reality we must you will want to control trailer brakes as you finish and try to straighten out. deal with. Eventually with a big and heavy enough trailer even a F450-F550 truck will be much lighter than the trailer..
My personal feeling is I would much rather have a bit beefier tow vehicle to start with which provides a firmer platform (IE stiffer springs, firmer shocks and some added weight to match closer to the trailer's weight). But obviously not many people are willing to step off the 1/2 ton platform because they prefer the softer ride and a perceived lower cost to buy and a couple of MPG better mileage when empty.
Agreed that with the correct trailer brakes, the tow vehice can stop the trailer, even in an emergency stop situation.  I'm more interested in an emergency "maneuver", such as swerving to avoid another vehicle or something.  In that scenario, the trailer brakes are of little value, and the mismatch in weight between the trailer and the truck becomes a major factor in control (or lack thereof)..
You should get out and test that.  In an emergency swerve  you will want to use trailer brake control to finish the maneuver to help bring trailer back into alignment.  How do you think onboard TV electronic trailer anti-sway works?
You want the real deal then get a Hensley or Pro-Pride hitch as once the hitch is locked it’s no longer a hitch but a steering component.
So far as stiffer springs go . . no,  it’s the FF/RR weight balance + the percentage on the RR axle with as much suspension compliance as possible on a pickup. Softer is better. Stiffly sprung is likelier to lose the tire contact patch.  Weight mismatch doesn’t mean much as it’s maybe 2/10s of a second difference once the LEVER with a trailer at the end of it has gotten the drive axle tires free of traction.
