johndeerefarmer wrote:
Edd505 wrote:
I have an 80 gallon above rail and the hose folds into the bed. There is a B&W Companion hitch behind the tank. I installed the nozzle to the drivers side and fuel from it, fresh fuel goes in the tank so it's rotated. I changed the pictured Fil-Rite pump to a GPI pump after two Fil-Rites failed.
The truck I have on order has the camera that is used to hitch up the fiver or gooseneck. I have to make sure whatever I put back there doesn't block the view of the camera
Nor sure where that mounts, I lost my rear view with the RV tailgate. I do have a white stripe in the middle of the tank and another on the pin box of my 5W. Line them up backing under, I do get out to check height just before hooking.
