ShinerBock wrote:
So everyone who spends more money on higher trim options, 4wd, or premium engine options gets no value out of it and it is just bad financial planning? Huh.
My company has over 500 trucks in our fleet across 120+ dealerships nationwide. We analyze the cost of every vehicle for future buying decisions and budgeting. The total cost of ownership difference between gas and diesel trucks is generally less than $2000 even those is states with high diesel prices such as our California. In locations where the price difference between gas and diesel fuel is lower such as our Texas locations, diesel trucks actually ends up being the cheaper option. Hence the reason I have said multiple times in the past for people to do the numbers for themselves because the fuel costs, taxes, resale values, and so on will not be the same.
People often ignore a lot of things like the factor that even though the oil/fuel filter change on my Cummins cost $150 and the oil change for a 6.4L gas engine like my truck is $80, they ignore the fact that the 6.4L requires the oil changed at 8k instead of the 15k on my truck. They also ignore the fact that by the time most expensive items like turbos and injectors need to be replaced on my Cummins at 350k, the 6.4L engine will be long past its life.
So lets put your argument to a gas half ton engine upgrade like going from a base 3.3L to a 5.0L which costs $1,995 up front. The 5.0L gets about 2-3 mpg worse fuel economy than the 3.3L and it has a higher maintainenance cost so that the cost of ownership keeps increasing the longer you own it. The same holds true for almost every gas engine option upgrade in half tons yet I never hear any of the half ton guys talk about talk about a payback or break even point like the 3/4 and 1 ton gasser guys do when trying to justify their purchase.
comparing apples to oranges when you mention trim levels. talking in circles.
you cite numbers that apply to trucks that are driven 100,000 miles a year.
so these diesel engine trucks will reach the break even point in 1 year and
in the next 2 years of operation will save them money.
yet you ignore that most campers will drive 200 to 1,000 miles a year camping.
which does not even provide the opportunity to reach the break even point
after 20 years of driving.
todays gasoline engines go 300,000 miles. Chances are after 10 - 20 years
most times it does not pay to rebuild the engine because overall condition
of deterioration of the pickup/suburban to time and normal wear and tear the
truck one would be better to buy a new and better pickup that will have
more power, mpg, payload, towing, braking, handling, ride.
MPG is not the only factor in buying a truck.
30 mpg car or 5 mpg school bus, which is better.
bus holds 60 kids drive a 5 mile route, 5 mpg/60 students delivered.
bus used 5 gallons
30 mph the driving time is 6 minutes
car with driver can fit 3 students
car has to drive that loop 20 times, car drives 100 miles, used 3.33 gallons
car has to drive that 6 minute loop 20 times
