Jim2007's avatar
Jim2007
Full Synthetic oil in 2016 Dodge diesel
Hi All. I just switched from conventional oil to full synthetic oil. The dodge owners manual states that oil changes are needed every 14K miles or after 6 months or if the on board oil indicator states it is time. Which ever of these evens occurs first. My question is does anyone really put on 14k miles before changing the oil? With conventional oil I changed the oil at 3K to 5K miles. This is my first experience with using a full synthetic oil. At lease half of my driving is with the 5th wheel trailer (weight about 9,000lbs ready to camp) attached. Thanks for the comments. Jim2007
  • Next time you change your oil, send a sample to Blackstone Labs and you will get back a very detailed report showing how much life, if any was left in your oil. Thus you would know going forward about how many miles to run before dropping the oil. Plus their analysis will tell you just about everything you can think of about the condition of your engine.
  • Hi Trckrig; I will check the dodge owners manual to find out if the filter needs to be changed earlier than 14K. Thanks for the comments. Jim2007
  • I usually run 10,000 miles on my synthetic oil between changes, but have done both longer and shorter.
    Does the book say anything about changing oil filters earlier?
    Bill
  • Don't you trust Dodge? I suggest following manufacturer's recommendations. These on board computers can determine oil life. Trust them.
