tropicdad
May 19, 2013Explorer
TECMike wrote:
Many years ago, the factory fill for Corvettes was Mobil 1 full synthetic. I do not know what they use now. Perhaps Corvette engines are broken in before they leave the factory.
I have been told a lot of regular oils today have more synthetic components in them than ever before. I use regular oil in our Mercury Mountaineer 4.6L V-8, with its all aluminium engine.
I use regular Shell 15w-40 Rotella in our 2002 Ford 7.3L diesel. All it has had in in since new. I can find it at any truck stop on the planet.
However, I use Mobil 1 full synthetic in our Honda 3000 generator as I am sometimes forgetful to change it regularly. I used it as its first fill when it was new. No problems and no oil consumption at all.
My 2007 Corvette came from GM with Mobil 1 and that is the only oil it has ever had. I prefer synthetic because I believe it keeps the engine cleaner and it leaves a film on the cylinders for cold startup. Heat and dino oil can cause carbon buid-up and coking which is why you must keep your oil changed regularly. I'm probably biased from being a jet engine mech in the AF where we used Conoco synthetic oil and saw how well it held up under extreme conditions.
My 2011 Mazda CX-9 came with synthetic from the factory also.
I think its fine to go full synthetic at your first oil change.
