RollandBCExplorerSep 02, 2019Furnace blowing cold air onlyHi, I have a 1995 Prowler 22' and it seems like the furnace is only blowing cold air. It does state there is an AUTO Igniter but I can't see the pilot or flame or smell gas.
AJRExplorerSep 03, 2019IF you measured .47V across the switch wires at the switch. The switch is bad, replace it.
Related ContentFurnace runs but blows coldFurnace blowing cold.Heat pump blowing cold airFurnace blowing cold airfurnace fuse blowing
