ESDAExplorerAug 15, 2017Furnace clickingI have a new (4 months old) Highland Ridge trailer. we used it once so far and everything seems to be working great. Last night I was washing the trailer getting ready to hit the road for an upcomin...Show More
bobndotExplorer IIIAug 15, 2017pull the fuse, see if it stops clicking .... if so , I think you might have some water inside the furnace tube from spraying the water when you rinsed it. Moisture on the circuit board will do it.Use a hair dryer as best you can to dry things out . There was some info where this happened on a Jayco i will try to find it for you.here it is,http://www.jaycoowners.com/forums/f34/furnace-making-clicking-noise-36484.html
Related ContentFurnace clickingClick, click, clickFurnace making clicking sound when it is already runningclicking - water heaterGenerator Timer Click, click how to change
