RoyB
Nov 30, 2015Explorer III
These two photos shows the PLATINUM CAT Heaters installed on a cabinet door and has outside venting... Not certain if these are same design as a WAVE heater or not...
I don't think I would install any of these propane heaters unless they have outside venting. These propane heaters will consume all of the oxygen inside the trailer and will produce deadly gas fumes. These type of heaters must be used in VENTED areas.
I too have the portable Mr BUDDY heater to use for back-up heat but have to open my roof vent and one one side window vent to be safe using it. Seems like you are defeating the purpose of having a heater going if you have to open windows and vents to operate them inside your trailer.
My MR BUDDY heaters also produces a large amount of water when it is being operated. I actually have to set it inside a oblong skillet tray to catch all of the produced water...
I will not operate my MR BUDDY heater when we go to sleep. It gets turned off then...
Please check with others about these type of propane heaters producing deadly gas fumes...
Roy Ken
Roy Ken
44,068 PostsLatest Activity: Jun 10, 2026
