Mike008
Nov 30, 2015Explorer
Reddog1 wrote:Mike008 wrote:I think maybe your comfort level would be okay, if you had a better understanding on how the Wave heaters work.
I personally would not be comfortable sleeping in a camper with an unvented heater.Mike008 wrote:Respectfully, if you are interested in the subject, you should do a little research. Keep in mind, be specific in your research, Wave heaters and not simply propane heaters. Your post here suggest you have not done enough research.
The flue gases will contain CO2. If CO2 builds up and runs through the burner it forms CO. If I had to do it, I would definitely have a window wide open. I would not trust my life to a cheap CO or low oxygen detector.
Wayne
You would be correct, I have not investigated the Wave heater specifically. So let me ask you this, is it unvented as in the flue gases spill directly into the conditioned space? If so, do the flue gases contain C02?
44,071 PostsLatest Activity: Aug 16, 2026
