bigfootford
Nov 30, 2015Nomad III
Mike008 wrote:Reddog1 wrote:
Mike008, there is much more to the Wave than you appear to be willing to research. I post this due to your "flue gases" comment. I encourage you to do a search on Wave or Wave3. Lots of good information. I will not debate with you.
Wayne
I don't need to do any more research. If you read the reviews of the Wave 3 on Amazon you will find several people indicating the Wave 3 set off a CO detector in their camper.
This is a fact, If you have combustion generating C02 as a product of cumbustion that is passing through the burner it will generate C0.
Best read the reviews.... Naturally dust, improper ignition etc. and thus it can have a problem...
That goes with all LP products..
With Thousands of these units in use and no one dead most folks are using this device properly!
Here is a link that gets Mike008 fearing this device..
Amazon Wave3 reviews:
http://www.amazon.com/Camco-57331-Olympian-Wave-3-Catalytic/dp/B000BUV1RK/ref=cm_cr_pr_product_top?ie=UTF8
When lighting ours the door is open and we wait for proper ignition. Too much wind and it will not light properly as does many Gas devices... BBQ's, Grills, furnaces etc.
Jim
44,071 PostsLatest Activity: Aug 16, 2026
