Mike008
Dec 03, 2015Explorer
bigfootford wrote:Mike008 wrote:
Lol. I'm quite certain I understand it. Seems there are a few posting to this thread who believe these type heaters use some kind of voodoo to generate heat from propane and air and are much safer then other appliances burning propane. Guess what? It turns out what I've posted is correct. It's not magic after all. It's actually combustion. Shocking!
Well there ya go... Mike you have not learned or explained anything that most of us already knew. You are at the front of the class! Now there are some of us that are also at the front of the class and that is why we chose the Wave over other sources of alternative efficient heat which is safe when used properly... That is a fact you failed to understand.
Sadly there have been 100's if not 1000's of cases of HVAC leaks that have caused severe sickness and several deaths... Can't say that about the Wave heater can you?
Like any Oil, gas, propane etc appliances, HVAC etc systems need to be inspected and monitored with proper CO safety devices to insure folks stay healthy. The Wave is no different but It sure as hell is easier to inspect and monitor and fix/repair.
So Mike thanks for letting us know about that VOODOO thing... and reminding us that there are some folks that are like you and some folks like us!
Don't you go out and buy a Wave heater now, hear!
Jim
I'd say based on this response, what I have posted has completely flown over your head.
