Strabo
Oct 15, 2016Explorer
Old-Biscuit wrote:
Propane on and flowing (light off ALL stove top burners on HIGH to place proane regulator in service and establish flow)
Good 12V DC is required....furnace uses DC power
So either fully charged battery or Shore power connected so converter can supply DC
Thermostat....check that it is set to HEAT
Then you have to set temp to higher temp then room is at.
When you set t-stat you should hear it 'click' and then furnace fan should run for 30-90 seconds before you hear propane fire off (might take a few attempts until propane flow gets to furnace gas valve)
No click at t-stat...then no DC to t-stat
Check that main dc fuse is not bad (DC Dist Panel...with AC Panel/converter)
X2
