mrbreeze_az
Oct 16, 2016Explorer
Old-Biscuit wrote:
OK.....
It works as explained in prior post
RV Furnace (Suburban/Atwood) basically work the same....same type of components, same safety features, same circuit paths. Not much difference regardless of WHAT trailer they are installed in.
Turn it ON
Highest setting on t-stat (warmer)
DC goes from DC Dist Panel where the fuses are to furnace and to t-stat
When t-stat Clicks DC goes from t-stat to furnace circuit board and allows the DC from fuse to go to fan motor.
Until fan comes on NOTHING else will happen
Furnace is directly opposite the furnace vents on drivers side of trailer.
You need DC to furnace.....simple as that
What is inside that panel below fridge?
Is it the AC Circuit breakers/DC fuse Panel or is it the furnace access?
What Suburban Furnace MODEL??????
Answer question and help can be provided.
Otherwise.take it to dealer for warranty work
The trailer is in storage but I am pretty sure the furnace is behind one of two service panels below fridge and stove. I checked the fuse for the furnace at the power center and it is good. I will try your suggestions this weekend and see if I can save a warranty trip. Thanks for your help.
