mrbreeze_az
Oct 18, 2016Explorer
Thanks!
When I remove the t-stat to check for loose wire I will bypass it like you said. It's funny you mentioned making sure the unit is straight. That is one ting I had them fix after walk through. It was mounted crooked on the wall. Could be a loose wire from them working on it. I like the digital one you showed. Will definitely go that way if it's bad. Maybe do it anyway once I get the furnace working. Thanks! This is my 5th RV and I still have a lot to learn!
