We are traveling in cooler weather and I am wondering if I can run furnace at the lowest setting while on the road? Assuming adequate power to run the fan and propane supply. Thank you.
Been running with fridge and heat on for years. Never a problem. Fridge is run on 12 volt and heat is ignited by a glow plug. If I may suggest putting all of your bedding in the overhead stuffed up against the front wall to use to better insulate. And definitely use the overhead vent insulation of your choice. I have never run the temp above the lowest setting of 50 degrees.
