awfulart wrote:
Old-Biscuit wrote:
On your thermostat placing fan in ON position will only run A/C blower.
Furnace fan will only work in auto with heat selected.
Open outside compartment cover (remove the screws in frame)
Look inside for an ON/OFF switch and circuit breaker (could be combined)
Make sure the switch is ON and push reset button on circuit breaker.
If OFF or not reset no 12V power to furnace.
Thanks, but i had looked before for a switch or fuse or circuit breaker but cannot see one. I think I will write Atwood back and ask them if there is one> I did get a manual on line from Atwood, very helpful and prompt. I will take a look there and see if there is a diagram.
thanks again.
You looked in the outside compartment and no switch/circuit breaker??
Mounted on frame in front of blower cover...top middle area???
Another possible location would be on side of furnace cabinet (access from inside rig in area where furnace is installed)
