enblethen
Aug 14, 2018Nomad
You can test using an ohm meter.
Go to mid point of what you think is the center of the circuit. Cut it open there. Test from the fuse panel to see if positive is showing resistance. Take lamps out for good reading.
Are there separate switches on the light fixtures? Make sure they are off for first test, then turn on and see if reading changes. this should isolate area of problem.
Is there a vent in area? If so that could have been wired for fan. Can check by removing garnish. Wires are usually tucked in ceiling.
