azrving
Aug 14, 2018Explorer
If you were to put a 12 volt bulb in place of the fuse and the system has a short in it you will see the bulb illuminated. With it illuminated try working through the string until the light goes out. I had a fan wire fall out of the wire nut and touch the frame. You could have a bad bulb, broken bulb socket, wires rubbing in socket, wires popped out of wire nut or wire shorted to frame.
Have you or anyone done any other work on the rig before this problem showed up? Did you install anything like coat hook, shelf, anything?
