1stvee
Sep 29, 2013Explorer
FYI Axel Failure
FYI-Has anyone had this problem? I purchased my 2011 Cruiser RV 24SD ViewFinder new. Used it about 3000 miles each year 2011 & 2012. I pulled & packed the wheel bearings each year. Jan 2013 had my loc...
Gdetrailer wrote:
Not really.
Lippert like Dexter manufactures the axles to the SPECIFICATIONS GIVEN TO THEM BY THE MANUFACTURER OF THE TRAILER.
Niether Lippert or Dexter sells to the general public.
The axle tags specify the MAX weight allowed for the entire axle/wheel assembly which is including the wheels. It is taken as a full assembly and the weakest component of that assemble mandates the max load available.
For instance, my Dexter axles have a tag of 3300lbs but yet the axle is in the 3500 lb "class" of axles and uses brakes and drums for 3500 lb axles.
Lippert gets a bad name more so since they manufacture so many axles when it is actually the manufacturer of the entire trailer SPECIFYING the axle weights..
