1stvee
Sep 29, 2013Explorer
FYI Axel Failure
FYI-Has anyone had this problem? I purchased my 2011 Cruiser RV 24SD ViewFinder new. Used it about 3000 miles each year 2011 & 2012. I pulled & packed the wheel bearings each year. Jan 2013 had my loc...
1stvee wrote:But it had been improperly serviced since it left the manufacturer as a unit.
Colliehauler is correct. I should have said; I had an Axel Assembly failure. The Axel Assembly was shipped to the Trailer Mfg. as a complete unit, Axel, Hub w/bearing races & bearings, Backing Plate w/brakes, all assembled ready for the road. I don't know what failed in there. After putting out the fire. The only thing left was parts of the brakes, heavy damaged hub & races, bearing bases stuck on spindle & a nut. Thank You.
1stvee
