woodworker414's avatar
Nov 04, 2021
Garmin Basecamp Problems
Good morning fellow truck campers.
I recently purchased the Garmin RV 890, I really like it. I have always purchased a Garmin gps. I have been learning Basecamp, I like it.
I can pick my own route and then export it to the RV890. When I open Basecamp and connect the gps to my laptop, Basecamp opens a small window, "Problem connecting to the device, error code, garmin/gpx/ current.gpx. I googled the error code and Garmin gives steps to delete the issue. I follow the step and deleted the corrupt current gpx file.
Then I start to mark my route, by placing waypoints, but somewhere on the route Basecamp does not follow the route that I have marked and willy nilly goes where it wants but will come back to the last waypoint that I had put on the map. Well I don't want to wander all over the countryside., I want to go down the roads I picked. I have called Gamin numerous times. The last time the guy said I see you have called before, Yes, because the issue has not been solved. And he kinda talked to me as if I was a waste of his time. UUUMMMM I was really looking forward to using Basecamp to explore.
Hope I explained this clearly. Has anyone who uses Basecamp had this issue?
Does anyone know of a alternative program that I can use instead Basecamp, Or a different gps device to replace the RV890.
Any input will be appreciated.
  • dsteinman
    Thank you for the reply. When you are creating a route, using waypoints, are you creating the route on the RV 890 or on Basecamp?
    I have very serious vision issue. I can not help in navigation when on the road. I can set up a route on the laptop and export it to the gps, because I use a reading aide device . I have looked at RV Trip Wizard, but have not really explored it. I really want to be able to export the created route to the gps.
    I will have to explore RV Trip Wizard more to see if a created route can be exported to the gps.
  • I don't know if you are using the Trip Planner or not, since I don't. But, I select waypoint and add them to a trip that I have created. These are on the left side on the screen. When you select them to create a trip, you have to select them in the order that you want for the trip.
    I also have the RV890 and like it, so I wouldn't change it.
    Lately, I have been using RV Trip Wizard for planning trips, since I had always used RV Park Reviews to find RV parks. I have not tried uploading or saving the file for the GPS.
    David
