Cardno7 wrote:
Pulled boats for many years, now have a Rockwood Minilite 2014s. Pulled by Ford F150 Lariat. Gas mileage went from 16 mpg to 8mpg. Just want to see if this is about the average drop in mpg. Don't see this drop in pulling the boat.
Since there is no such model as the Rockwood Minilite 2014s I suspect you mean it's a
Rockwood Minilite 2104S which is about a foot shorter but a whopping 600 lbs pounds heavier than my own Coachmen Freedom Express 192RBS. :E Loaded and ready to camp my FE typically averages ~ 4500 lbs and I'm towing with 5.3L Chevy Avalanche with the older wide ratio 4-speed transmission coupled to a non-tow friendly 3.42 axle ratio. I typically average 12+ miles to the US gallon towing this trailer compared to when I used to tow a 27' KZ Spree that ran ~ 1000 lbs heavier and with which I typically saw ~ 10.5 mpg. Based on the size and weight of your Minilite your mileage to me is excessively low, though a lot depends on how much of a lead foot you have, the truck's axle ratio, and whether it has one of the newer narrow ratio transmissions, none of which you've detailed for us. There's no way you're going to match gas mileage towing any type of barn door down the road to towing a boat but regardless, towing a trailer the size of yours with any 1/2 ton I'd want to see 11 to 12 mpg.
