Basswest1's avatar
Basswest1
Gas VS Diesel FORD For Truck Camper
Hey all, new to the forum and new to truck campers.
I do not have a camper or a truck yet but have been doing a lot of research and trying to come up with a solution for my specific needs.
The biggest debate seems to be Diesel vs Gas in my decision making.
First off, the truck camper I am looking at is around 3050lbs DRY with no pop outs. I will also be towing a bass boat which will weigh a maximum of 5000lbs soaking wet.
I realize that if cost weren’t a factor, it would probably be a resounding DIESEL due to the overall efficiency aspect of a diesel while towing, however, my research is pointing toward gas for several reasons.
The truck I am looking at is a F-350 (SRW) with the 6.2l gas engine, which properly rigged is rated for 4,500lb payload capacity and more than enough towing capacity after that. The reason I am leaning toward this setup is that #1, I really want to stick with a SRW truck versus a dually because it is going to be my primary vehicle too, and the SRW Diesel offerings dont have that kind of payload capacity due to the added weight of the Diesel engine and I need the cushion in payload for added gear. #2 the up front cost of a diesel is a huge factor, with the cost of fuel also being pretty costly, not to mention maintenance. I dont plan on keeping the truck for more than 200k at most, so longevity of a diesel is not a factor for me.
Now, the reason I am writing this is because after all my research of the pro’s and cons, I have not been able to find any reports from owners of the 6.2l gas engines on how they perform with a truck camper. All my needs seem to be getting met with the 6.2l but it all comes down to real-life performance.
Anyone have experience with this engine? Is gas going to perform ok for my needs, or am I going to be turning around and getting a diesel?
Thanks in advance.
  • BradW wrote:
    What axle ratio?
    4.30 is the one that I’m seeing would be best.
    What axle ratio?
  • 6.2 with deep gears will do what you want just fine.
    Don't buy it because of the additional "payload" it offers. Long discussion and every 4th thread is about the same ___ so you can read up on that.
    Have had 2 of them. A 2012 and a 2015 model 6.2 F250s both with 3.73s and wouldn't have hesitated to to drop a camper on them and tow a small/med trailer at the same time. (Company rigs, not camper hauler)
    The engine/drive train combo is as reliable as anything out there IMO.
    The most similar "load" I hauled/pulled was about 1500-2000lbs in the truck bed and an enclosed high profile trailer weighing about 4klbs. Got the same mileage as towing a 10-14klb flatbed trailer with low profile load. Average about 8mpg towing, 13 empty.
    The truck you're contemplating will be a great fit for your intended purpose.
  • Similar camper weight, not towing anything just yet, air bags, stable loads, and Ranchos. Handles like a dream.
    Driving through hills and mountains with tow mode on feels like you're driving a standard.
