jefffoxsrExplorerAug 24, 2016Gasoline and clear coatWill using gasoline to remove bugs from the front of the vehicle compromise the clear coat or damage it? Will isopropyl alcohol damage the clear coat? Thanks.
vortec22ExplorerAug 24, 2016Go buy some "Bug and Tar" remover. Should be readily available. May want to re-wax the area after you use it though.
Related ContentGasoline/Diesel ShortagesBest Roof CoatingAre you familiar with Duck Coat Roof Coating??Green GasolineReformulated Gasoline
