rjstractor
Nov 10, 2017Nomad
Txsurfer wrote:
So I just watched a video - in TX you are supposed to have a Class A non-commercial license for anything over 26,000 CGWR. It specifically stated that that number is determined by adding the truck GVWR and the trailers GCWR. Interesting..
The term "Gross Combined Weight Rating" (GCWR) is used in two totally unrelated contexts. One is the manufacturer GCWR, which is the total combined weight that the vehicle is rated to move as explained above. The other, which is what you are referring to, is the number that states refer to in determining regulations for a particular combination. In the case of Texas that's requiring a non-commericial class A license to drive a combination of 26,000 pounds GCWR or more if the trailer also is over 10,000 GVWR. In this situation, GCWR is simply the sum of the truck's GVWR and the trailer's GVWR. For example, a SRW 3500 series truck with an 11,400 GVWR pulling a 5th wheel with a 16,000 GVWR would require a non-commercial class A license in Texas and some other states, where a DRW truck with a GVWR of 14,000 pulling a fifth wheel with an 11,000 GVWR would not.
44,072 PostsLatest Activity: Aug 23, 2026
