4x4ord
Nov 10, 2017Explorer III
Dayle1 wrote:
GCWR is not a legal issue, it is the manufacturer's rating for warranty (if they could ever prove you exceeded it). It is what the manu. feels is a max weight to pull with reasonable performance and not damage the drivetrain, etc. But to specifically answer, you would not add truck and fiver GVWRs because that would double count the pin weight. Also in Tx you can register the truck for a GVWR higher than the manu. Number. You just can't exceed any axle or tire rating.
I had a new truck that the turbo was acting up on. When I brought it in under warranty to be looked at I asked where I could unhook my gooseneck trailer. When the service manager came out saw what I was pulling he asked what it weighed (over 30,000 lbs) then told me I should have a F550 for that load. Anyway it was no problem getting the turbo replaced under warranty.
44,072 PostsLatest Activity: Aug 23, 2026
