ford_coupeExplorerJun 15, 2018gear ratioHow do i find out what rear ratio do i have 2006 3500 ram 4x2 auto matic cummins without jacking truck up off ground?
normal_daveExplorerJun 15, 2018Type in your VIN number here in the box next to Equipment Listing, hit search, you'll get every detail of your truck as built from the factory. you can print it or save it as a .pdf file for later.Ram Truck Equipment Listing
Related ContentRear gear ratioTowing with 6.2l 3.23 gear ratiorear axle gear ratiogear ratiosGear Ratio
