ford_coupe
Jun 15, 2018Explorer
gear ratio
How do i find out what rear ratio do i have 2006 3500 ram 4x2 auto matic cummins without jacking truck up off ground?
Best to then tie/tape a length of string on the drive shaft. Note a
datum.
Then roll the vehicle one tire rev using the valve stem as a datum
Count the full turns and the fraction left. That is the diff ratio
and makes no matter what size tire or suspension lift, etc.
Remove the string.
