kansanforlifeExplorerJan 30, 2014gear ratioHow do you find out what your gear ratio is on rearend. Have a 1999 dodge 1500 5.3.
wmosesExplorerJan 31, 2014If the rear gears were changed then the only way is to open up the diff and count teeth.
Related ContentRear gear ratiorear axle gear ratioTowing with 6.2l 3.23 gear ratiogear ratiosGear Ratio
