Surf_Bums's avatar
Surf_Bums
Generator Opinion
We have an Amerilite 19rbc Travel Trailer. Considering purchasing a generator for boondocking purposes. The most I care to run is my TV/DVD combo and the Air conditioner that is 5000 BTU. What would be the minimum type generator stats I could use to power these items and power them at possibly the same time? Looking to keep it inexpensive if possible.
Thanks for the opinions.
Bums
  • Surf Bums wrote:
    Something along these lines would be acceptable then?
    Champion 46596 3,500-watt gasoline-powered portable generator (not CARB) with 196cc Champion OHV engine
    If you are really going to boondock with no one else around that would be fine as long as you don't mind listening to something that sounds like a loud lawn mower. If you will EVER camp near others, please get a quiet generator like the Honda or Yamaha.
    Champion 46596
    Not if you were camped next to me, especially if you're running it to watch TV at night. Nobody needs to run a loud 3500w generator to watch tv. Most people use inverters for that. I see RoyB said the same thing.
    Also, that gen is overkill for your useage requirements. Please, think about your specs rather than saving a few bucks. Your neighbors (and you) will thank you for it.
  • RoyB's avatar
    RoyB
    Explorer II
    The 5000BTU air conditioner should run just fine from a 2KW Honda type generator... This is not the bigger problem however as most public camp grounds have generator run time restrictions in place especially here on the East side of the US and you will only have certain windows to run your generator in. Definitely not enough time to cool down a trailer. Most times are from 8AM-10AM in the mornings and then again from 4:30PM to 7:30PM in the early evening. The NATl FOREST area may have 8AM to 8PM available to run the generator but this is not always the case. We have not found any public place that allows the generartora after 8PM at night. Let alone to be able to run them all night...
    What most folks do in these cases is to beefup the trailers with more battery capacity to run all the 120VAC items you want to run from an installed INVERTER conencted to the battry banks and all of the 12VDC items direct connected to the battery banks.
    Then the trick is to be able to re-charge your battery banks within the generator run time restriction times to get the batteries back up to their 90% charge state. Failure to always get back to the 90% charge state will most likely result in your batteries starting to lose their performance specs operations. You can do two weeks of this type of charging between 50% and 90% charge states and not do harm to your deep cycle batteries using smart-mode technology charging techniques... After that however you have to charge up to a full 100% charge state which will take around 12-13 hours to fully charge your batteries. This of course cannot be do at most public camp grounds with their generator run time restrictions in place. This is usually when we come home off our trips and get our batteries back up to 100% charge state at home...
    It works good for us doing this type camping off the power grid but does take some initial planning and battery system beefing up.
    Roy Ken
  • Just make sure you get one that runs quiet. Most generators are very loud, even when you try to contain the sound. This does not go over well at campgrounds. The quiet generators like the Honda are more expensive, but well worth it.
  • Something along these lines would be acceptable then?
  • There are a lot of generator options. I'd probably say the most popular would be a Honda eu2000i Companion, just due to versatility. If you need more power than one 2000 watt model can give, you can pair it with another 2000 watt generator for 3500 watts.
    The TV/DVD is a small fry when it comes to power consumption. The A/C and the microwave are the big hogs.
