lawrosa wrote:
Fred_n_Jo wrote:
Talking about the converter. The shore power goes to the breaker box where one circuit then goes to the basement storage area and that is where the converter plugs in.
So you have a seperate charger? The charger plugs into the outlet you decribe?
Because usually the converters are all in one, charger/converter. Like this..
If so whats the make?
And it only trips the breakers when generator is run correct?
Sounds like a bonding issue with the generator...
Has it ever worked?
![](https://cdn-tp1.mozu.com/17063-26403/cms/26403/files/ddb5ea18-cea2-4500-bcd3-6bae2cc83b16?max=500&_mzcb=_1521039943009)
Your version of “usual” doesn’t match mine. I’m used to converters that have normal plugs on them the plug in to a receptacle, like this one:
https://parts.unitedrv.com/products/inteli-power-9200-converter-chargerYou were making an assumption about the OP’s converter and then asking questions that really were relevant to the issue. He said it was plugged in within the first post.
I don’t think the OP was trying to be rude, just directly saying he had what he needed. No reason to take it so personally.
