4x4ord
Nov 28, 2014Explorer III
Git er done
So far we are impressed with the new Peninsular 6.5 diesel in the old truck. About 27 mpg (imperial) and very good power. Maybe we need a couple more tires under it though?
By putting more air through the engine, not only can you inject more fuel/get more power but higher air volume also provides for much lower exhaust gas temperatures and therefore less demand on the cooling system.
blt2ski wrote:
Nice thing about a 6.5, decent fuel mileage. Cheap to work on. Problems are known, most are very easily fixed. Power, yeah a bit on the under stated side compared to todays motors. STILL, a 200/400 motor is nothing to sneeze at, and they will overall pull upwards of 8-10K without issues at reasonably decent speeds etc. Keeping them cool is the main issue.
I went from the pre97 cooling mods, to the post 97 with dual t-stats, high gpm pump that is about double the water flow, and a 7 instead of a 5 blade fan with a different fan clutch, made a lot of difference for me, IE I could use the AC vs not and still have lower engine temps.
Marty
Cummins12V98 wrote:blt2ski wrote:
Do as I did to my 96. Put an upper 6 leaf instead of the 5 pack, with all the leafs being 1/16" thicker. Gave me an 8500 lb pack instead of STD 6400 rated spring pack.
I've also heard good things about the penninsular diesel for 12+ years now. If I still had the 96 and that motor went out, I would get one from them.
Marty
What is the difference? I just know from 3 crate 6.5's being replaced they have thin cylinder walls.
Marty
